Radio Buttons
May 14, 2008 12:00 AM
And something as elegant as Greg's solution is just begging to be in an action group if you're using Lectora 2007. It makes things a little easier to code.Although, if you are having trouble with the invisible button going away, you might consider putting a delay in the hide action. Just set it to like 0.2 seconds or so. I've seen Lectora choke up on actions before, where it does a later action before the first action is complete. I think this happens only when you do some modifying of variables, so it might not be an issue here.Kevin
