Quiz feedback problems
Using Lectora 2007.I have a question object that has a variable assigned to it called "question_005"I have an action that will show the correct feedback only on the condition that the variable "question_005" has the "is correct" relationship.When I answer the question, the correct feedback shows no matter if I answer correct or incorrect.I have had this happen too many times with other questions and it is becoming very annoying, to say the least.The only way I have been able to fix the problem is to delete the question and start over. Even if the same variable (question_005) gets assigned, the question feedback then works fine.I can't figure out why some of these questions break or how to fix them without deleting them and starting over. There must be something getting corrupted in Lectora.Has anyone had similar issues? Did anyone figure out what causes this?
