question and result at the same side
Hi,
thanx a lot for all the good answers. I've got one more questions:
I wanted to create a multiple choice question with more than one right answer. I found out how to give a reply, if the learner chooses all the right answers (with On Click). But I still don't know how to give a "try again", if the learner doesn't choose all of the correct answers (like an if-than-else-function). How can I command my "check it" button to spit out to different answers ("right" and "try again") according to the choice.
And: I don't like pop-ups cause they don't have our design and if you close pop ups, all the informations are gone. But you have to do it - otherwise your window is full of these pop ups. Second reason - we wanna create browser based tests. A lot of Browsers use pop-up blockers. In fact it's just how it feels about using and working with it but most of all they are just ugly
