Publishing Problem while using ext HTML
June 10, 2006 12:00 AM
Dhakshna:I use the product AND it doesn't influence the Lectora course at all. You still develop and publish using Lectora. It's not a replacement but an alternate way to run your Lectora course as an executable.The benefit is that you only have to publish to HTML - so the files can be used for the web OR for the CD. You still get to use cookies, and javascript, and external html files. Everything you use for your web course you use for your CD course.This software simply launches your html files in an interface that looks as if it is not being run through a browser interface. It actually is, but the user is not aware of it. It can be run full screen or in a window.I'm a Lectora fan, but I need the power of javascript for my CD delivered work - this additional software allows for that.SB
