Text Block and .OnDone. vent Problem
Hi , I'm developing an E-Learning application using Lectora. I have some queries. 1. How to create scrollbar for a Text Block(When I use more lines of text) 2. When a voiceover complets then some animation will be shown, after competion of that another voiceover should play. For that I gave "Done playing " action. When I publish as HTML I got an error, it says 'OnDone events not supported for objects'.(I'm using Internet Explorer 6.0). Please suggest. (pls Note : When I publish as single exe it works fine)Thanks and Regards, --Dhakshna
