Login Sign Up
ELB Learning Logo
Topics
Members
Website
Knowledge Base
New Topic
Menu
  • Topics
  • Members
  • Website
  • Knowledge Base
  • New Topic
Archived
Report Abuse
Publishing Problem while using ext HTML
@pdmoor
June 10, 2006 12:00 AM
Buy this software - I've used it often. Publish to HTML and run off a CD or HD as an executable.The exe sources the Operating Systems browser resources and you can run the html published files as if it was a single program.That way you can use javascript, cookies, etc.here's the link:http://www.cloanto.com/menubox/SB
pdmoor pdmoor
@pdmoor
View Profile
More From pdmoor
Scroll bar for Text Box
March 15, 2006 Reply 0 Upvotes
Text Block and .OnDone. vent Problem
July 30, 2005 Reply 0 Upvotes
Publishing as HTML
July 16, 2005 Reply 0 Upvotes
Placing flash files on one another
Publishing as HTML
Publishing as HTML
Publishing as HTML
Lectora --> Flash communication
April 27, 2005 Reply 0 Upvotes
Join The Discussion
Sign Up Login
