Published pages blowing up... help!
March 14, 2009 12:00 AM
Resolution: The final answer was to split up the original action into 2 actions, eliminating the need to use the "Else" section. Additionally, I had to set the first action to delay (I chose .2 seconds). There are still JS errors on the page, but I have tested it extensively on my hard drive and on the LMS and it seems to be functioning the way it should. Viva web 2.0!Resolution: The final answer was to split up the original action into 2 actions, eliminating the need to use the "Else" section. Additionally, I had to set the first action to delay (I chose .2 seconds). There are still JS errors on the page, but I have tested it extensively on my hard drive and on the LMS and it seems to be functioning the way it should. Viva web 2.0!
