Published pages blowing up... help!
March 14, 2009 12:00 AM
In your second screenshot you have a javascript error which is preventing the screen from rendering properly. (Lectora uses Javascript to position the different elements on the screen).First thing you want to do is an error check, then double check that all your actions are pointing to the appropriate areas.It can also help if you double click on the yellow triangle in explorer (lower left hand corner) and tell us the error message that you are getting.
