Published pages blowing up... help!
Update: After some experimentation (and help from Ben!), I have narrowed the problem down to the action on the Submit button (see screenshot above) that pulls up one of two feedback/pop-up windows based on whether the question was answered correctly or incorrectly.After digging a little further, I found that the page "blows up" (see txt only graphic above) when there is an "Else" set (e.g., "If the conditions are not met, perform the following action). This is what the final action looked like that was causing problems: On Mouseclick go to [Page] Correct Answer (open in new window)... Conditions: ONLY IF Question 1 is correct... Else: Go to [Page] Incorrect Answer (open in new window).To narrow down the problem, I separated the one action into two separate actions, so that the Else section did not have to be used. This allowed the page to be displayed correctly, however, the some of the actions would not work correctly for the Submit button (which was now thankfully visible). So I went in and used the "Else" section on my newly separated actions and selected "If the conditions are not met, perform the following action: 'none'"When I did this, the page "blew up" again.So... I'm not sure what it doesn't like about the Else section for this action, but that's as far as I've gotten. If anyone has any ideas, please post!!!
