Publish problems
Hi Vickie,Try replacing the BMP with a JPG version of the same file. This will be more compatible with browsers and have a smaller filesize and therefore load faster.I have had problems with text resizing by small amounts when publishing to HTML, plus the line spacing IS different. It's quite a pain in the...The only way that I have found to fix the line spacing reliably in all browsers is to create the text line-by-line! This means that you can reliably line up graphic decorations, such as styled bullet points. I did mess around trying to override Lectora's styling, but found cross-browser support issues that were not easily solved.I would love to hear if anybody has found a cure to the problems of getting Lectora to be truly WYSIWYG with text and HTML.All the best,David
