Problems with Text...
February 16, 2009 12:00 AM
Only workaround is to have just one hyperlink per block and put the action on the text block and make the text look like a hyperlink. If you have more than one, break it into separate text blocks.Only workaround is to have just one hyperlink per block and put the action on the text block and make the text look like a hyperlink. If you have more than one, break it into separate text blocks.
