Problems with publishing to HTML
Sounds like you may have a JavaScript error. Look in the lower left corner of the browser window in the status bar. Do you see a yellow triangle? If so, you have some kind of Javascript error. Hard to diagnose w/o the course. For more help, we will need to see some portion of the course. If you feel uncomfortable posting your full course or it is too big, make a small version containing just a few of the problem pages. Then use File menu > Export > Zip to create a file to post. Post that in the Files section of the Lounge and post here that you have done that. Make sure that you mark the file Public.
