Problems with publishing to HTML
December 15, 2009 12:00 AM
Thanks Julee for your prompt reply!
I know what you are refering to in the general properties box 'Initially Visable' if unselected, like you say there is no action for the object to show. However I have actions applied to each object to show, but I'm still experiencing problems with these showing once puiblished. The work perfectly well when publishing to an single .exe file, but when either publishing to HTML or SCORM, nothing works.
I'm using Lectora V2006, with IE6 so I'm thinking it could be either version or browser related.
The investigations continue. I will be sure to post any findings, as I come across them!
Good Luck with yours
Regards,
Ellen
