Problem with a preconfigured Lectora popup message
Hi all,
I have created a test pool with 20 questions. Lectora randomly takes 10 questions and creates the test.
To pass the test, the user has to answer 60% of the test correctly. At the end of the test, the results are sent via E-Mail to my account. (Unfortunately, we don’t have a LMS at the moment).
If the user passes the test a page ‘Passed’ is shown. If he fails, a page ‘Failed’ is shown.
This works fine.
Now my problem:
At the beginning of the test the user has to enter his name. (To realize this, I used the standard functionality in the test properties on the results tab.)
Later on, the name is written into the test results that are sent to my account.
After entering his name, the user can click ‘OK’ or ‘Cancel’.
If he clicks OK, everything is fine!
However, if he clicks ‘Cancel’ the page ‘Failed’ is shown.
Is there a possibility to change the ‘Enter-your-name-popup’?, e.g. delete the Cancel-Button, or close the course if Cancel is clicked…?
I hope someone has an idea.
Thanks a lot!
Hi all,
This works fine.
Now my problem:
Thanks a lot!
