Printing problems since 2006 sp2
April 5, 2006 12:00 AM
I had this same problem. Got this msg from support today.
Quote:
It appears to be an issue added in the SP2 update if you attempt to print a page that contains printable objects inherited from the title level. If no objects are inherited from the title level, the page prints fine.We're looking into a fix for this. For now, if you change your title to be an AICC/SCORM title (from the content tab of the title properties), it will place all objects under a single AU instead of at the title level. You should now be able to print the pages without error. I can't give any time frame of when this will be fixed, but we are looking into it.
cheers, ben
