AICC + javacript titlemanager Problems
I am in a situation where a large customer does not allow the use of Java applets. In the LMS I am using SCORM requires a Java api as adapter. The AICC does'not. I am publishing in AICC so i am able to bypass this limitation.The problem which occurs is that using the default title manager (java) the system wil'l not work beacause it stops Java api's. Using the javascript title manager seems to be a good idea. But It returns a System error en does'nt go past the loadingscreen (Loading..., Coursename). HELP PLEASE.
