pop up problem
No. You're fine then. I'm not sure how you have your "Continue" button setup on the PopUp page, but the first action completed should be setting the PopUp_Close variable to one and then followed by the Exit/Close action. If you use the OnClick tab in the button properties, then set that action to modify the variable and then add an action to close the popup window. Hopefully its that easy!?!
