pop up problem
May 8, 2007 12:00 AM
If you have an action that resets the PopUp_Close Variable to zero on the next page, then it shouldn't continue going through the next page. If it is...I'm not sure why.If you have an action that resets the PopUp_Close Variable to zero on the next page, then it shouldn't continue going through the next page. If it is...I'm not sure why.
