Thank you for that code, David. Could you clarify a couple of things for me?
First off, am I correct in assuming that the HTML object needs to begin with ?
Second, even though I'm running on IE6, I cannot get the correctPNG function to fire off. I can confirm that it's not firing because I placed a couple of alerts in the code. The HTML runs fine, but it seems the conditional is not firing off the correctPNG function. Is there something else that needs to be considered? Sadly, my HTML coding is quite subpar.
