@graphics2go
July 7, 2009 12:00 AM
Internet Explorer does not like .PNG files so if your audience is IE, you should consider .gif. I'm assuming you're using .PNG for transparency purposes, so .gif is really your only choice. If no transparency go .jpg.
v11.3.1 not printing LMS generated variables on certificate
Page Count in DIfferent Language
