please help action/target nightmare
August 22, 2007 12:00 AM
I'm afraid it is something I run across during my work as well, more often than I want to.The problem seems to be that Lectora can only be given specific or fixed links, dynamic links to item's don't work (dynamic links to external documents do work, fortunately). As far as I know, there is not quicker option to do this.You might want to try and get your hands on a java-script batch process to make the deadline without to much stress. It won't help you in the AWT-file, but might just work in the published version (because I know changing 400 links is a true pain the human rear).Good luck on this one!
