Flash / Lectora communication problems
December 8, 2005 12:00 AM
It appears that you are using the correct action "javascript: text290.actionShow();" - as long as there is a text box on the page with the ID of text290Javascript actions will only work within the web browser and not within any other applications. Have you tried publishing out to html and seeing if it works correctly in the published content? It will not work from within Lectora.
