please help action/target nightmare
August 22, 2007 12:00 AM
I did not have any trouble with the action TARGETS. When I copied and pasted the pages into an empty title, some of the Value fields disappeared. Maybe better to do this via phone. When are you available Sunday or Monday or Tuesday? I live in US - Eastern time. Call 678-571-4179. If I don't answer, leave a msg to arrange a time.Meanwhile, try saving the pages as library objects and using them instead of copy and paste. If it works, locate your Library folder - Program Files > Trivantis > Lectora and create a short cut to the Library. Put on desktop. Open and view in list format. then you can drag and drop library items.Edited By: Ben Pitman on 2007-8-26 9:20:26
