Login Sign Up
ELB Learning Logo
Topics
Members
Website
Knowledge Base
New Topic
Menu
  • Topics
  • Members
  • Website
  • Knowledge Base
  • New Topic
Archived
Report Abuse
paragraph spacing attributes incorporated into styles
@sholderman
February 8, 2012 12:00 AM
We need to have the paragraph spacing attributes incorporated into text styles' capabilities. Currently, the line spacing is way too crunched for easy reading and each text box must be adjusted, adding much time to a project.
sholderman sholderman
@sholderman
View Profile
More From sholderman
scroll bars appearing
June 11, 2013 Reply 0 Upvotes
fill in the blank question format with multiple text fields and one submit button?
June 6, 2013 Reply 0 Upvotes
Camtasia 8 generated m4v or mpeg4 or mp4 videos not running
December 5, 2012 Reply 0 Upvotes
mp4 not playing when published to html on web
certificate resolution
July 20, 2012 Reply 0 Upvotes
Tweaking CSS for web font use in LMS/SCORM application
May 2, 2012 Reply 0 Upvotes
rendering text as image
May 1, 2012 Reply 0 Upvotes
When submitting exam, can't find page (?)
March 7, 2012 Reply 0 Upvotes
In the event that boxes overlap... in exe files
February 7, 2012 Reply 0 Upvotes
Snap Trial
January 31, 2012 Reply 0 Upvotes
Difficult to Get Registered into the Ceritfied Lectora Author program?
January 27, 2012 Reply 0 Upvotes
Join The Discussion
Sign Up Login
