Options for removing IE navigation?
September 30, 2008 12:00 AM
One method I've employed to remove IE navigation buttons is to create a "pre-launcher" Lectora file that uses an action to open the actual course in a new window via URL, removing all IE components. You can also remove window scrollbars and resizing options, if you wish.This works great for our HTML testing, as this simulates how our LMS will display the course. Not certain how it will work in your environment. Just a thought.
