Needing some help :D
A couple of things could be happening with the audio: 1) the audio files may not have copied over to your program when published, 2) the audio files may have been compressed during the publishing which caused them not to play. What version of Lectora are you using? If Versions 8 or 9, try un-checking the audio compression box on the Compression tab that pops up when you are publishing to HTML. I have had to do that with my files before to get them to play. Otherwise, look for an error on the page in the form of a little yellow triangle in your lower-left corner when going through your published piece to see what it says is going on and if it is an internet explorer or javascripting error.
As for the drag and drop; I have never used one in any of my programs but looking at the Help Contents page for Drag and Drop questions, it appears that your text does need to be an image if it is to be dragged and dropped somewhere. I hope all this helps.
