Multiple Values for Test Questions - is it possible?
Just thought of an easier solution if you are using multiple choice questions. Start each option with (A), (B), etc. Then on the Condition tab for your actions, instead of "equals", use "contains" and then the (A), (B), etc. That way you don't have to worry about typing in the whole response, possibly getting it wrong, and possibly changing the option later. Plus, it makes your actions easier to re-use on other questions.
