Test Contents Not Displaying
April 15, 2008 12:00 AM
I'm using Lectora 2006.I've got a title that is made up of two test versions preceeded by a page that contains a "Yes/No" dropdown box. The concept is pretty simple - choose "yes" and you go to version 2 of the test; choose "no" and you go to version 1 of the test.Anyway, each test has 10 sections to it. The problem I'm hitting encountering is this: regardless of what is chosen in the dropdown box, the next screen (which should be page 1 of the assessment) displays nothing but the background graphic - no question, no distracters, no navigation buttons - nothing - except the background graphic IF I SET THE ASSESSMENT TO PULL 1 QUESTION RANDOMLY FROM EACH TEST SECTION. If I set the assessment to pull 10 questions randomly from the test as a whole, it works. However, that's not the functionality I need; I need to be able to pull one question from each test section.I called & left 3 messages for Trivantis Support today undefined I need an answer to this ASAP. Can someone please offer some insight?
