Multiple Values for Test Questions - is it possible?
 Not sure if I remember 2006 but here goes...
on the question object (ie. Choice 1 button) if there is a tab that says "On Select/Change:" you can set an action to modify a variable based on which button they click. so you can set A to modify var1 = 2, or B modify var1=1, etc.
melston74 said:I don't know if this is even posible, but here goes: I need to create a test in Lectora (2006, SP5) in which selecting different distractors scores different point values. For example.. If the user selects distractor "A", they get 2 points; if they select distractor "B", they get 1 point. If they select distractor "C", they get 0 points. Setting up the initial value is easy enough, but I'm lost & unsure about setting up multiple point values for a single question.
