Multiple Values for Test Questions - is it possible?
August 26, 2009 12:00 AM
As long as they change their answer before hitting submit, the value of the variable will update whenever they click a new choice, as the value is set to update on the change of the item. SO clickinging B after clicking A will set the variable to 2, then if you click C, it will change the var to 3 from 2, etc. It will update with each click.
melston74 said:I don't know if this is even posible, but here goes: I need to create a test in Lectora (2006, SP5) in which selecting different distractors scores different point values. For example.. If the user selects distractor "A", they get 2 points; if they select distractor "B", they get 1 point. If they select distractor "C", they get 0 points. Setting up the initial value is easy enough, but I'm lost & unsure about setting up multiple point values for a single question.
