Please take this with a pinch of salt by somebody who doesn't use a LMS.
Your file seems to highlight a few questionable areas to me.
Your bullet points have changed on the LMS, as has the overall size of the text, including the screens alignment.
I have experienced several issues when using bullets points within Lectora, can you take them away and see what you get.
I'm sure you've done this but thought I help if I can.
Rig_Girl said:I've posted a file with screen shots of the alignment issues we are running in to, the file name is "Multi - lines of text not aligning". We're under the gun to publish this to our LMS this week for SME review but are having problems getting our multi rows of text to left justify. We know about converting text to an image, and that does correct the problem, but creates a different problem (fuzzy text). Let us know what you can - thanks
