Font Issues - Multi - lines of text not aligning when published
October 1, 2009 12:00 AM
Rg, you have already highlighted the text, right click to see the alignment tools available for text, right? Also, if you cut and pasted the text, check there is not autoformatting embed in the text. You may have to check this by clicking the icon to show all formatting. Remember, if you have any links in the text, changing it to an image by affect the links working properly. Good luck!
Rig_Girl said: I've posted a file with screen shots of the alignment issues we are running in to, the file name is "Multi - lines of text not aligning". We're under the gun to publish this to our LMS this week for SME review but are having problems getting our multi rows of text to left justify. We know about converting text to an image, and that does correct the problem, but creates a different problem (fuzzy text). Let us know what you can - thanks
