MP3 sound plays before page load
One way to do this is to add an audio icon in the main section at the top. Then on the page you want the audio, use two actions. One is used to Change Contents, set the audio icon as the target, and import the audio file you want for page.The second is set to on show/play/This should fix it. Then you will only have one audio icon in the file that you can update whenever you need audio.
