Mastery score in manifiest file problem
If your title contains a Lectora test, then a line similar to the following should appear in the imsmanifest.xml file: 0.75If your course does not contain a Lectora test, then no mastery score will be included in the imsmanifest file. If you are using a test from another source, then I would recommend adding a blank test in the Lectora title that no one can access via navigation and then the value for the mastery score should appear in the course. Again, if your title does not contain a test then no mastery score is needed.
