Login Sign Up
ELB Learning Logo
Topics
Members
Website
Knowledge Base
New Topic
Menu
  • Topics
  • Members
  • Website
  • Knowledge Base
  • New Topic
Archived
Report Abuse
Macro? (Importing audio)
@jmccahill
April 6, 2009 12:00 AM
1. export as XML
2. Find and replace
3. import edited XML to Lectora
4. publish out however you want
Joe GEICO
@jmccahill
View Profile
More From Joe
Graphic disappearing on page transitions (leaving white box)
October 18, 2010 Reply 0 Upvotes
White flash when moving from one page to the next??
October 15, 2010 Reply 0 Upvotes
Course word count?
October 14, 2010 Reply 0 Upvotes
Does this ASP Code for submitting variables to a database look right?
July 16, 2010 Reply 0 Upvotes
Set variable contents according to the contents of a text box
July 15, 2010 Reply 0 Upvotes
Entry Field to Variable
File to Disable Horizontal Scroll Bar
October 1, 2009 Reply 0 Upvotes
Recommendations for Portable Digital Recorder for Voiceovers
July 19, 2009 Reply 0 Upvotes
Media Player use ActiveX
April 9, 2009 Reply 0 Upvotes
More Control to Customize Defaults
April 8, 2009 Reply 0 Upvotes
Free Graphics/Video/Audio Sites?
February 8, 2007 Reply 0 Upvotes
Additional Templates?
January 23, 2007 Reply 0 Upvotes
Join The Discussion
Sign Up Login
