Linking Captivate Projects
July 18, 2008 12:00 AM
What version of Lectora are you using? Also, are you using a goto web address action for going to the second swf file? If so, it won't work in preview mode but will show you the Micrsoft Live Search window as you describe. I usually have to publish mine to HTML to view these actions correctly.What version of Lectora are you using? Also, are you using a goto web address action for going to the second swf file? If so, it won't work in preview mode but will show you the Micrsoft Live Search window as you describe. I usually have to publish mine to HTML to view these actions correctly.
