linkage in flash library doesn't work
March 7, 2006 12:00 AM
Hi,I have created a few flash files, which are using "linkage" in the flash library to import images into the flash movie during runtime. I use this for images that are used in several swfs in order to save file size. Imported into Lectora this works fine in Lectora preview. But after publishing the linked image is not showing in the flash file. Is there any way to fix this?Thanks!jazzletzEdited By: jazzletz on 2006-3-7 4:49:9
