linkage in flash library doesn't work
Not really ... have you tried just opening the swf2 file directly in the IE browser? If so, can it find the image in swf1? The reason I ask is then you will know if the problem is within the Macromedia plugin or not (since you are only dealing with the straight files).Tim
