linkage in flash library doesn't work
March 7, 2006 12:00 AM
Not really ... have you tried just opening the swf2 file directly in the IE browser? If so, can it find the image in swf1? The reason I ask is then you will know if the problem is within the Macromedia plugin or not (since you are only dealing with the straight files).Tim
