Lesson without tests - problem publishing to SCORM
That message in Lectora indicates that you need either an action to modify the AICC_Lesson_Status or have a scored test in the title. The reason for this is if there was no score and no action to modify the status, the course would always remain incomplete for the end user. There would be no way for user to truly complete the course. Therefore, you can do as Shawn mentions above to set the score or you could add an action to modify the AICC_Lesson_Status and set the value to completed or whatever value your LMS is looking for. Just keep this in mind in case you set the score to 100 and when you exit the course in the LMS you see a score of 100 but the course remains incomplete. Some LMS' do not have the ability to do a score/mastery score comparison and therefore the course will always remain incomplete unless you add the action to modify the AICC_Lesson_Status.
Lorcan said:Hi. I've included an introductory lesson in my course (without tests) and have problem publishing it to SCORM. I get the following error message: "This course is missing a scored test or a Modify Variable action for either AICC_Lesson_Status or AICC_Score. You must have at least one of these items somewhere in a course for AICC/SCORM compliance. This is how the course can be set as completed within the Learning Management System." It looks like I need to Modify a variable for this. Would anyone know how this is done? Thanks Lorcan.
