Lesson without tests - problem publishing to SCORM
June 6, 2009 12:00 AM
Hi Lorcan,
When you publish to either AICC or SCORM a test or test score is mandatory. On the last page of the course that the student sees you need to create an action to set the score variable value. Use the following:
Action - Set ScoreAction type: On ShawnModify VariableTarget: AICC_SCOREValue: 100Set Variable Value
Then when you publish it should work fine.
Shawn
Lorcan said:Hi. I've included an introductory lesson in my course (without tests) and have problem publishing it to SCORM. I get the following error message: "This course is missing a scored test or a Modify Variable action for either AICC_Lesson_Status or AICC_Score. You must have at least one of these items somewhere in a course for AICC/SCORM compliance. This is how the course can be set as completed within the Learning Management System." It looks like I need to Modify a variable for this. Would anyone know how this is done? Thanks Lorcan.
