Lectora Help
July 5, 2016 12:00 AM
Hi,
I need Help regarding below points(Lectora 12)
- Is there is any way in Lectora for customize the bookmarking popup.
- How to disable Backspace Button in lectora as currently it is not working in Mozilla using Javascript.
- How to set Page Orientation in Lectora for IE 8 for printing Certificate, as currently it is getting truncated when i use print preview.
Help needed, thanks in Advance.
Hi All,
Although anybody haven't replied to my queries, this is amazing.
Anyways i have resolved all the issues by myself in Lectora :)
Regards,
Jitendra
How did you fix the certificate print out? As it stands it really bugs me.
Hi...
Although this is a bug of of lectora itself...just change the orientation before you print in the print popup which appears when u click print certificate...it can't be sorted in any other way.
Regards
jitendra
