ignore case within entry field?
Thanks guys. What I've got is 20 hidden terms, and the user has to enter them. Every time they get one, it is revealed on the same page. I played around with the fill blank question, but it's not really what I'm after. What I need is each correct word entered triggering a word-specific series of actions to work out the points, set scores etc. So the associated variable isn't just either true or false.What I'd like to do is have something run before the string analysis that takes the entry field and converts its contents to lower case.Edited By: finsbury on 2006-11-10 10:23:47
