Login Sign Up
ELB Learning Logo
Topics
Members
Website
Knowledge Base
New Topic
Menu
  • Topics
  • Members
  • Website
  • Knowledge Base
  • New Topic
Archived
Report Abuse
ignore case within entry field?
@finsbury
November 9, 2006 12:00 AM
If you are using a fill in the blank question, it is case insensitive. Could you set it up as a question and then modify your variable based on that?With an entry field, it's case sensitive. I suppose you could use multiple conditions to check the various case combinations.
finsbury Mowat
@finsbury
View Profile
More From finsbury
AICC / SCORM Heartbeat
July 30, 2009 Reply 0 Upvotes
Else tabs in library objects
September 18, 2007 Reply 0 Upvotes
buttons causing streaming video to stop
March 13, 2007 Reply 0 Upvotes
Join The Discussion
Sign Up Login
