How to Mute the Audio of an Imbedded FLV Audio File in Lectora?
September 11, 2009 12:00 AM
When I open a .flv video file in Flash the parameters can be set. Like what skin I want to use for playbackcontrol and wether or not to autostart. There is also a parameter called volume. 1 being the highest. So making an action that modifies the volume parameter of the flash file from 1 to 0 should do the trick. What code that should be I don't know exactly... but maybe someone else does.
However this only works on a file by file bases... so no total global control for all the Flash files used in your course at once... or you must create an action group that modifies all the volumeparameters for your course. But I don't know if that's possible.
Good luck.
