How to get SCORM module to resize for ipad
July 19, 2013 12:00 AM
I am creating SCORM 1.2 compliant courses using Lectora V11 and publishing to Moodle. We want to ensure our courses are compatible for viewing on an ipad.
My current template dimensions are 980x640, but when viewed through Moodle using an ipad the right and bottom of the screen are cut off and it doesn't allow you to scroll to see those cut off bits.
I understand the meta tags (viewport) added by Lectora V11 help this issue when published to html, but it doesn't seem to help for SCORM modules.
Does anyone have any experience of this, or resolutions? I'm hoping not to have to physically re-size and move all objects on all pages to make the pages smaller for viewing on an ipad.
Any thoughts would be appreciated.
Discussion (2)
Hi,
I am having the same problem. Did you fix it?
Roberto
