Hot Spot questions
September 22, 2005 12:00 AM
Just wanted to add something to InsTrainer's explanation in case it was not obvious.After you create the invisible buttons and set the action of the button to set the variable for the question, add two actions to each invisible button. The first action is On MouseClick, process the question. The second action is On MouseClick, go to next page.Make sure that the question is set to give feedback and enter appropriate feedback. This way, when the user selects the hotspot, they are immediately given feedback. When they select the OK on the feedback, they are taken to the next question.
