Help with re-appearing objects
March 30, 2009 12:00 AM
Hi Kevin,
I just down loaded the .zip folder and tried to open it. If i try to unzip it with WinZip, I get a message that the file is corrupted. If I try to open it with Lectora, I keep getting the following error message:
Data file is corrupted or saved by a different version of this product. Not sure what to do from here. Any suggestions?
Thanks for all the help.
