Help with re-appearing objects
March 30, 2009 12:00 AM
Well, I'm still getting used to this Lounge, but I should have an alternate method at:
http://www.lectoralounge.com/profiles/kevinelmore/files/103
See if that helps.
I chose this method because the items would show in a more sequential fashion. Also, if you change the timing of one instance, then you don't need to ripple through the entire timeline to change the others.
Kevin
