Help with re-appearing objects
March 30, 2009 12:00 AM
Hmm, I'm using Lectora v9, so we should not be having any compatibility issues.
Still, it's possible that the zipped file was corrupted. I did rename it after zipping it; that shouldn't be a problem, but I am never surprised when something breaks in Windows.
I have added a new file called "Actions.zip". I will not rename it this time. I also tried putting it in just my Files without the Public box checked. If I understand the new Lounge, this means you can see it in My Files, but it won't clutter up the files section, since it's not of use for the general populace. Let me know if you cannot see this file, and I'll upload it publicly.
Kevin
